How do spells like Control Water, Shape Water, and Create or Destroy Water (and possibly others?) work with water in pipes (let's say about a foot in diameter if that matters)?
Consider two cases:
- enclosed pipes in which the water flows
- a pipe that is open on one end and the water flows out of that end and falls on the floor
In both cases I will assume that the supply of water is virtually unlimited.
- Can the spells change the direction of the flow?
- Can they stop the water from flowing?
- Does destroying the water have any effect since new water will immediately fill the space?
- Can they (in the latter case) only affect the water that is already out of the pipe or also that which still is in the pipe?
I assume there will be an issue with my ability to see the water (at least in the first case) but what if I drill a small hole into the pipe?
Or what if it's made of glass?
What if I am in Border Ethereal?
