Does casting a spell using a spell slot higher than the spell's level upgrade its spell level even if it doesn't have additional effects from being upcast?
This is for the purposes of determining healing from goodberry while playing a Life Domain cleric.
Yes, using a higher-level spell slot results in a higher-level spell.
The rules for casting a spell in a higher-level spell slot state:
When a spellcaster casts a spell using a slot that is of a higher level than the spell, the spell assumes the higher level for that casting. For instance, if Umara casts magic missile using one of her 2nd-level slots, that magic missile is 2nd level. Effectively, the spell expands to fill the slot it is put into.
Some spells, such as magic missile and cure wounds, have more powerful effects when cast at a higher level, as detailed in a spell's description.
This first paragraph make no mention of changes to the spell's effects, so it doesn't matter if the spell's effects change - it still fills a higher slot. The second paragraph indicates that sometimes this upcasting changes the spell's effects.
As outlined in the highest scoring answer of the Q&A Does a Life Cleric casting Goodberry at higher spell levels get more potent Berries?, upcasting goodberry does mean the berries restore more points as a Life Domain cleric, because of the Disciple of Life feature.
Thomas Markov
  • 148,772
  • 842
  • 1,137
Yes
Thomas has answered your most direct question regarding the Life Cleric's Disciple of Life feature, but this also extends to other things which relate to spell level.
For example, if you are dealing with a Rakshasa's Limited Magic Immunity, upcasting your spell to higher spell slot gives you a means to affect them with that spell.
Also, if you've upcast a spell beyond 3rd level, you have made it harder to end using Dispel Magic.
Pyrotechnical
  • 34,356
  • 127
  • 233
