What is better for my Macbook's Pro 13' 2015 battery life: 1) Loading it to 100% and then using it to ~20%, loading it again OR 2) Using it plugged in to the power adapter all the time?
Asked
Active
Viewed 169 times
2Possible duplicate of Should laptops remain plugged in when their battery is 100% charged? – DavidPostill Nov 29 '15 at 10:24
I would recommend using your battery at least a few times a week, and recharging it afterward, even if it is only for a short time.
Apple's recommendation would be to charge and discharge your battery at least one time per month. I wouldn't go below 20% discharge for the best battery life. Apple also recommends that if you're storing your Macbook for an extended period of time, to charge it to only 50%, and powering it off afterward, for the best battery life.
Gavin
- 173
