I've been given the following question:
Any list of integers can (uniquely) be broken into "parity runs" where each run is a (maximal) sequence of consecutive even or odd numbers within the original list. For example, the list List = [8,0,4,3,7,2,-1,9,9] can be broken into [8, 0, 4], [3, 7], [2] and [-1, 9, 9] Write a predicate paruns(List, RunList) that converts a list of numbers into the corresponding list of parity runs. For example:
?- paruns([8,0,4,3,7,2,-1,9,9], RunList).
RunList = [[8, 0, 4], [3, 7], [2], [-1, 9, 9]]
Here was the code which I tried and it seems to work with the above sample case, thanks to one suggestion, but I've got an issue where when I run paruns([8,0,4], RunList). it prints RunList = [[8,0,4],[]]. Any suggestions would be appreciated :)
paruns([],[]).
paruns([Head | Tail], [E, O | S]) :-
   even([Head | Tail], E, Last),
   odd(Last, O, Last1),
   paruns(Last1, S).
even([Head | Tail], [], [Head | Tail]) :-
   Head mod 2 =:= 1.
even([Head | Tail], [Head | L], Last) :-
   Head mod 2 =:= 0,
   even(Tail, L, Last).
even([],[],[]).
odd([Head | Tail], [], [Head, Tail]) :-
   Head mod 2 =:= 0.
odd([Head | Tail], [Head | L], Last) :-
   Head mod 2 =:= 1,
   odd(Tail, L, Last).
odd([],[],[]).
false
  • 10,533
  • 98
  • 192
Iza
  • 33
A major attraction of Prolog is its relational nature. This means that we can often use a Prolog predicate in several directions, if only we stick to sufficiently general primitives.
In this concrete case, since you are reasoning over integers, I highly recommend you use your Prolog system's CLP(FD) constraints to benefit from this generality. Please see for more information about this important declarative feature.
In addition, since you are describing a list, consider using DCG notation ().
Here is a relational solution for your task:
parity_runs([], [])     --> [].
parity_runs([E|Es], Os) --> [E], { E mod 2 #= 0 }, parity_runs(Es, Os).
parity_runs(Es, [O|Os]) --> [O], { O mod 2 #= 1 }, parity_runs(Es, Os).
We can use it for the test case you posted, where the list is specified:
?- phrase(parity_runs(Es, Os), [8,0,4,3,7,2,-1,9,9]).
Es = [8, 0, 4, 2],
Os = [3, 7, -1, 9, 9] ;
false.
Moreover, we can also use it in other directions. For example, suppose that the runs are known, but the list isn't:
?- phrase(parity_runs([2,4], [1,3]), Ls).
Ls = [2, 4, 1, 3] ;
Ls = [2, 1, 4, 3] ;
Ls = [2, 1, 3, 4] ;
Ls = [1, 2, 4, 3] ;
Ls = [1, 2, 3, 4] ;
Ls = [1, 3, 2, 4] ;
false.
Moreover, we can also post the most general query, where nothing is known:
?- phrase(parity_runs(Es, Os), Ls).
Es = Os, Os = Ls, Ls = [] ;
Es = Ls, Ls = [_2012],
Os = [],
_2012 mod 2#=0 ;
Es = Ls, Ls = [_256, _258],
Os = [],
_256 mod 2#=0,
_258 mod 2#=0 ;
Es = Ls, Ls = [_826, _832, _838],
Os = [],
_826 mod 2#=0,
_832 mod 2#=0,
_838 mod 2#=0 ;
etc.
To fairly enumerate answers, we can use iterative deepening:
?- length(Ls, _), phrase(parity_runs(Es, Os), Ls).
Ls = Es, Es = Os, Os = [] ;
Ls = Es, Es = [_168],
Os = [],
_168 mod 2#=0 ;
Ls = Os, Os = [_550],
Es = [],
_550 mod 2#=1 ;
Ls = Es, Es = [_770, _776],
Os = [],
_770 mod 2#=0,
_776 mod 2#=0 ;
Ls = [_770, _776],
Es = [_770],
Os = [_776],
_770 mod 2#=0,
_776 mod 2#=1 ;
etc.
mat
  • 40,080
  • 46
  • 74
    thanks for all the advice, i actually went out and learnt about clpfd today and i can see its got a lot of use! i've actually just started prolog and coming from C its quite a difference but your write up was very educative! thanks again! :) – Iza Mar 31 '17 at 09:15
TL;DR: Find the "right peg" for the "hole" in split_if_adj/3 and you're done!
This answer is based upon:
So, basically, we're delegating the cumbersome and sometimes tricky task of handling lists recursively to a higher-order predicate which we customize appropriately.
Sample query:
?- split_if_adj(dif_parity_t, [8,0,4,3,7,2,-1,9,9], Rss).
Rss = [[8,0,4],[3,7],[2],[-1,9,9]].
Note that above query succeeds deterministically.
repeat
  • 19,674
  • 52
  • 161
I think you have just a typo, in the first odd/3 clause. With the following code
paruns([],[]).
   paruns(Last1, S).
   Head mod 2 =:= 1.
   Head mod 2 =:= 0,
even([],[],[]).
odd([Head | Tail], [], [Head | Tail]) :-  % corrected
   Head mod 2 =:= 0.
   Head mod 2 =:= 1,
   odd(Tail, L, Last).
odd([],[],[]).
I get
edit
A possibility to discard empty sequences (should occurs only at first or last position, I think... so maybe a better approach would be to sanitize the outcome for these cases):
paruns([],[]).
%paruns([Head | Tail], [E, O | S]) :-
paruns([Head | Tail], R) :-
    (E=[] -> R=[O|S] ; O=[] -> R=[E|S] ; R=[E,O|S]),
   paruns(Last1, S).
CapelliC
  • 58,738
  • 44
  • 87
  • Thanks so much I don't know how I didn't see that, only now I have one small other question if you could help. When I run it with the above example it gets perfect output, however with 'paruns([8,0,4], RunList).' it prints RunList = [[8,0,4],[]]. Any suggestions on how to fix this?? Thanks again :) – Iza Mar 31 '17 at 09:21
  • Sorry, the easier 'solution' leads to ugly code, anyway, see my edit... – CapelliC Mar 31 '17 at 10:01
