While learning more about Servos, the main thing i have learned is that, Servos (SG90) need PWM signal with the frequency of 50Hz. And the duty cycle of the frequency is used to rotate the angle of the motor.
I know generating PWM with variable duty cycle is possible in PWM pins using Timers but i don't understand how the arduino Servo.h library makes digital pins act like PWM too , whenever i connect the servo to any one of the digital pins of the arduino and code accordingly.
So how does Arduino 'Servo.h' Library manage to make a digital pin act like a PWM and what should the native AVR C code for this action look like?
I am trying to avoid third party libraries as much as possible and trying to learn Embedded systems thoroughly.
Please do not suggest big banging PWM method.
Thanks...
Please do not suggest big banging PWM method... why do you say that if you do not know how the library does it? – jsotola Dec 29 '21 at 17:59
