Is there a difference between unlikeable and dislikeable? It feels like there is, but I'm uncertain how to explain it.
RegDwigнt
  • 97,231
    The same as the difference between any un-word and dis-word. There is no special significance to likeable in relation to the use of the un- and dis- prefixes. – Kris Jan 20 '12 at 12:39
    @Kris and what is that general difference? – TrojanName Jan 20 '12 at 12:52
Assume there are three states of fondness for something.
  • Like
  • Neither like nor dislike
  • Dislike
Disliking something is not the same as not liking something. If I don't like peas, I will eat them with no pleasure. If I dislike peas, I will actually find them nasty.
So, dislikeable is something that's easy to dislike.
Unlikeable is something that's difficult to like.
slim
  • 10,254
  • My interpretation. unlikeable ... you cannot fall into the first group, "like". dislikeable ... it is possible to fall into the last group, "dislike", but perhaps also possible to fall into the other two groups, instead. – GEdgar Jan 20 '12 at 14:53
  • @slim thanks for the answer. It's useful to point out that 'dislike' is not the same thing as "not like". However, to me the word unlikeable implies that something is impossible to like, not merely difficult. – TrojanName Jan 20 '12 at 17:59
According to the definitions of unlikeable:
Adj. 1. unlikeable - (of characters in literature or drama) tending to evoke antipathetic feelings; "all the characters were peculiarly unsympathetic" 2. unlikeable - difficult or impossible to like; "a disagreeable and unlikable old woman"
and dislikeable:-
Definition: easy to dislike
the difference would appear to be that an unlikeable thing is something you don't or can't like, and a dislikeable thing is something you could quite easily not like (but that you have no particular aversion to at the moment).
Brian Hooper
  • 36,868
At first glance, it seems pretty straightforward. Unlikeable - 'Not likeable' (Not necessarily negative, just straddling the fence. Infrequent usage) Dislikeable - 'easily hated' or 'easily vilified'
Unless you mean the new 'unlike'-able, which is a sad result of the FB culture and not a real word.
forcrp
  • 71
  • Thanks but I don't fully agree with you. Unlikeable to me is a strongly negative term, implying impossibility of liking. – TrojanName Jan 20 '12 at 17:59
